B3422w5
Don, have you considered a session on a chassis dyno?
My engine is only 11.2-1 and made the most power at 34° on an engine and chassis dyno. It also made 30 more HP on pump 93 than it did on 98 race gas, it was built for pump 93 though. You may not need as much octane as you think you do.
nothing is readily available other than pump , and then 110. Nothing in between.
at 12.4 to 1, I feel extremely comfortable ( and safe)knowing 110 is the correct fuel.
it may not run any better with more timing, and I already have it correct, but when a guy as sharp as Chris Hardy gives me some pointers, I am gonna heed them and try what he says. If for no other reason because it doesn’t hurt to try.
