1971 Demon power booster with mc
J.B.
Florida
I have a 1971 Demon previous owner ran all new lines and disc front drum rear. I need to finish with a booster and master cylinder setup for disc front drum rear does anyone have a good source for bolt up ready booster setup there are a bunch that say for a/b/c 8” want to make sure its a replacement bolt up where i dont have to hack up my firewall
This should work right?
If you are not looking for a 100 points trailer queen, you can go for a generic booster.
Some months ago, my original Midland-Ross booster broke down. I had to replace it, but the OEM part has been impossible to find, and the refection kits well overpriced :BangHead:
So, I went for a generic 7" booster/MC combo found on Ebay for a fistfull of bucks.
Just had to slightly enlarge the 4 holes of the original mounting bracket.
Probably made in China, but works well with disks/drums and 7" diameter is enough for my modest slant 6.
Also available in 8" or 9" diameter, but room is counted in the Demon engine bay and it can be necessary to relocate the winshield washer jar. The original Midland-Ross booster is 7 1/2" in diameter.
Hope this helps
François
Hope this helps
François
Beautiful engine compartment!!
