Magnum r/t heads, are the corner bolts on exhaust wet?
4mulas
Fixem'up
Pacific Northwest
Bit of a cross post here in case not everyone looks at the magnum thread.
are the corner exhaust bolts on magnum r/t heads wet just the same as regular LA heads?
thanks
Do you have water coming out the exhaust or something? No water behind the end bolt with an RT
No.
I may need to service the steering box. So that involves loosening/removing the header to do so. Just want to be prepared and know if I should drain coolant first.
