Removing window tint
Princess Valiant
A.K.A. Rainy Day Auto
Colorado
So I have some glass from a dart that obviously spent some time with an owner of different taste.
It's purple and horrible looking so what would you guys use to remove it??
If the glass is loose acetone has worked for me. If you are SUPER careful you can do it in place
spray with an ammonia based glass cleaner, let it sit in the sun a bit.
Then go after it with a razor blade .
Allways use new razor blades and replace often, less chance to to scratch the glass.
We just use a steamer at the shop , to remove it for NY inspections. It will peel right off.
