[Found!] 318 , 340, 360 engine bracket
1969DartCustom
San Jose
Rating - 0%
0   0   0
Hi there, looking for the passenger side engine bracket for a V8 K member to 318 magnum (technically 340-360 should fit)
I don’t mind a 318 mount even if I have to make shims.
Currently swapped from a slant 6 k-member to a QA1 and realized my drive one fits but not my passenger side.
I’m located in San Jose CA
Figured I might check for just the passenger side one before ordering an expensive set.
Thanks!
passenger side is common to 273-360 it's the left that is different from 318 to 340
since the original kit I used was slant 6 to 340 , it came with the correct left side mount. The passenger side is this longer box looking one.
That sounds like whatever I find should fit even better!
