[WANTED] 67-76 donor metal where the shock bolts are inside trunk
TylerW
Elkton, TN
Hey guys:
I need to buy a chunk of good metal from someone. This is the portion of sheetmetal inside the trunk where the shock bolts are, as shown. I've never seen a car that had this damaged, but when a po swapped in an 8.25 into my SLANT SIX Swinger, they mangled that area on one side. Looks like they took a hammer to it. After that, it rusted away because of the water leaking into the trunk. I'd prefer the entire section to work with to help me locate the patch properly.
Please PM me with what you need for it including shipping to 38449.
Thanks.
When you say "the entire section" are you referring to what you have circled in yellow, or the whole over axle pan?
Hey guys:
Thanks.
I have the whole section. How much would you want?
Got a section out of a new piece of AMD metal left over that I didn't use
