Does anybody make these?
kdbunn
Gibsons BC
1967 Dart GT trunk molding clip. The moldings that go above and below the trunk finish panel. As you can see the stud is offset from center. I can't seem to find them anywhere and mine are junk.
Thanks. I looked at those but the 68-69 panel is one complete unit while the 67 is smaller with separate moldings above and below it so it doesn't work. One year only conundrum. :BangHead:
Thanks. Had a look. They have very little in the way of 67 dart parts and definitely no molding clip. Sigh.....
Post a want ad if you can't get a bite it looks like it could be duplicated...small machine shop or fab shop...Check with Hemissdart he might have something like that. Also year one makes a 67 gt dart finish panel clip with a stud that closely resembles that photo. I just saw it upon doing an image search for 1967 gt dart finish panel clips
Thanks. Those are the clips for the finish panel. Not the moldings that go above and below the finish panel. I will post a wanted ad. I thought someone would make them but I'm guessing there isn't a huge demand for them. I think a lot of guys replace the panel and molding with the one piece 68-69 panel.
I have seen folks pop rivet the old clips or other ones to the inside lip of trim panels. Seems to work good and you can’t see it after it’s assembled.
What you have, and the rest are in similar condition, doesn`t look too bad, I`d media blast and paint, and reuse them.
Lol. That's the best one. Most were rusted beyond use or broken. Believe me, I have been using up brain cells trying to figure a way to get this to work. I'm almost out of them now.:BangHead:
They would be actually be a simple clip to fab up, if you have the equipment. good luck
