Pictures needed of mounting locations for retractable 3-point seat belts
Duster_Dean
NEPA
Hi All,
The PO redid the interior on my 1975 Duster and only installed a simple lap belt anchored to, what looks like, a random bolt under the seat.
Can anyone provide pictures of where the retractable lap, or better yet, retracable 3-point seat belt mounts?
I ask because the same PO recarpeted the interior and covered where I believe the floor mount bolt goes along the inside of the rocker panel area. I also have the stiff one peice headliner so I cannot tell where that mounting point may be or if there is even one there.
I really want to install A.) retractable and B.) 3-point seat belts as the current ones really suck - I think it was just a 'must have' to pass inspection so the PO did the bear minimum.
Thanks in advance
The picture is the current set-up
Should go on the side rocker rail right about where the seat track ends. Feel around in that area.
Ok, thanks I'll try that.
I will probably have to take up the carpet and get more involved as the PO put sound deadening matting all through the interior!
