Heater control pins -help
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
Hi all,
Another member is in need of heater control pins to replace his broken ones.
I can have them made in Aluminum, but I need one to get measurements from.
It can be broken as long as the pieces are there.
The other member is going to try and get me dimensions but if anyone has a 67 up heater control they could loan me or sell me super cheap I would be interested.
If you have a broken pin but have all the pieces that would work too.
A secondary method is detailed photos and dimensions of the pin.
Pm me with what you have.
Moderators if you feel the need to turn this into a wanted ad that's fine but it's really about making a part. The getting a part is secondary.
I think I may have a control assembly in storage. I'm sure others have loose ones as well.
Alan
I may have found my AC control from my 67 Dart Convert #2 if it is where I think it is i'll be able to see if the pins are the same in it. (Fingers Crossed)
I'm pretty sure the lower lever is the same on both AC and heater controls, so the pin should be the same.
Alan
Now I have to get 67 Dart #1 out of the garage! Might have to wait a day or two!
Dried out enough.
Got the control
Good news and bad news...
Good news
I got dart #1 out
Bad news
AC control does not have the plastic pins. It has a peened in metal post.
Good news...
The blower motor switch was in good shape and I disassembled and cleaned and lubed it up ready for Dart #2
Which broadens my search criteria for heat only controls
