Vapor lock- additive?
An electric pump does fix v/lock. Modern cars use elec pumps.....& the same fuel.....& they don't get v/lock. Pump needs to be mounted near the tank.
So lets just forget modern cars also have very advanced EFI. Yeah, ok.
Quite agree! But it is still an elec pump pushing the same fuel to the engine....
I cured vapour lock on my 440 by removing the factory fuel pump & fitting a Carter #4594 elec pump.
VP lock is usually worse, or causes more problems, at idle & low cruise rpm. That is because the engine is using less fuel. The fuel stays in the pumped & lines longer....getting cooked by the heat.
