Several months ago I replaced the intermediate shaft on my 440 (solid roller cam) with a brass Milodon. The shaft that was in there was from 440 Source and I saw a video by Just Mopar Joe where he replaced his 440 Source shaft because it had play in it. Today I pulled the distributor to find out why the timing mark was jumping around. I put a screwdriver into the slot on the shaft and could wiggle it. I pulled the shaft out and found the teeth are really worn. Now it looks like I will need to pull the engine (only 1500 miles on the rebuild) because the cam likely is bad as well as brass shaving having gone into the engine.
Any ideas why the teeth on the shaft would have worn so much?
