This Bad Demon
Hey there. I'm using an in tank electric fuel pump with an universal fuel pressure regulator (carb/efi usuage). I've searched and searched but couldn't get a good answer. If I leave the vacuum port to atmospheric pressure it reads round 6 psi where I set it for carb usage. If I hook the line up to manifold pressure it drops to 4 psi. Should I leave it to atmospheric pressure or to manifold pressure? Also when it's hooked to manifold pressure it dips a lil when given gas... Is that normal?
