AJE Tubular Coil Over Front Suspension
Do the countersunk screws and washers go through the shock bolt hole? What are the short support sleeves for?
Yes counter sunk washers and short bolts secure the top of the shock mount to the factory upper shock mount hole. This is the bolt you leave a little loose at first when installing the shock mount. The other bolt and sleeve is the upper coil over mount. The sleeve part goes on the backside of the shock mount. That’s not in the doc but if you don’t there might be slight contact between the coil spring and upper A Arm.
Completely unrelated to your current discussion, but this photo makes it look like you have a ton of positive caster. Did you align the car yet?
Yes I did. It ended up with more positive caster than the previous alignment but I don’t have the numbers in front of me.
Added the Hellwig sway bar for a 73-76 A Body. Bolted up easy and luckily cleared my turbo hotside.
Hello friend, excellent project, a question, what part number of the sway bar did you put, since I am installing the same suspension on my 68 barracuda and the bar that I bought from qa1 is much larger, greetings from Mexico
You should probably confirm with AJE. The suspension dimensions of my car are more narrow than yours so it may require a different anti sway bar.
I sent an email to aAJE suspension and I didn't get a response, my problem is that I don't speak English to be able to make a call, a great favor, do you think you can help me contact aje suspension and see which sway bar I need, I will thank you very much
Drives great on the street. No issues.
Yeah but doing what kind and how much driving? Have you actually measured the Ackerman or toe change?
The way most people use these cars it would be pretty easy not to notice fairly significant bump steer and Ackerman issues.
