340 Exhaust Manifolds on Edelbrock Heads
Detroit Iron
California
This is kind of an exhaust topic..... and kind of an engine topic. So, gonna post it here in "general".
About ten years ago I put Edelbrock heads on a 340. The exhaust manifolds are '68-'70 castings. On the driver side where the manifold curves around the steering column; it curves back close to the block and actually came into contact with the lower portion of the head where it meets the block. (wish I had photos of this, but I do not) I had to grind away some material from the head which wasn't a big deal.
I am now building a 360 for a different vehicle, but I'm using the same combination of Edelbrock heads and '68-'70 style 340 exhaust manifolds. Question is, with the newer Edelbrock head castings.... do you know if Edelbrock has corrected this situation?
Yes, I could contact Edelbrock tech services with this question, but I'd rather hear real world responses from my community members here. Thank you.
I used a quarter 1/4 header flange on mine.
I ground some off the head and manifold as well. Little bit on each. I was grinding on both anyway. I don't have a picture of my early manifolds but did the same for then as well. Had them surfaced and I ported
Do these require two sets of gaskets? I would imagine you'd need a gasket on both sides of these flanges. Also who makes them, and can you possibly provide a part number? In the meantime... I'm gonna head over to Summit to start poking around. Thanks for the input.
I did find them made by Patriot. Both Summit and Amazon are out of stock. I ordered a set of Remflex gaskets. I think they are 1/8" thick. Hopefully that is enough. I really don't want to be grinding again.... ugh.
Back in 2000 when I put together a 340 with Edelbrocks & manifolds I uses spacers, then the next year I was at Spring Fling & wound up speaking with Steve Duilich and he mentioned he had ground the raised area down and wound up hitting the water jacket.... I would suggest using spacers, or at least be damn careful about how much you remove...
This ! ^^^^^^^ !
After being 2nd or 3rd attempt dealing with exhaust leak at manifold and resurfacing same my installer was over aggressive and got into jacket near # 7. Owner of shop had another set of comparable heads and did fresh valve job at his expense. I did spring for new SS valves and lost a few months.
We did go with 1/4" spacers as in post #2 which was dramatically simple and clearance was no longer an issue on 64 Dart. Ugh
This ! ^^^^^^^ !
Thank you for the input. I think I will go with a spacer on the driver side. Like you say, seems like an easy solution.
