Frt sway bar brackets
Bennoel 10
Toronto, Ontario
Looking for a pass side sway bar bracket that bolts up the k-frame on a 69 dart. I believe someone was reproducing the outer piece of this bracket. It was a repair piece as they tend to get damaged. I can't seem to find where I saw them or who was reproducing them. Pictures showing the damaged passenger side and the good driver's side. Any leads appreciated.
Thanks.
You could remove the brkt from the frame, install a standard poly bush and brkt on the bar, then build an adapter brkt to go between.
Another option is you could bend two 1/2 inch wide and one one inch wide by 1/8 strips, lap the center strip over the sides slightly and weld them together (looks like a top hat from the end), then weld to the brkt. About $10 worth of steel from the home improvement store.
Yes I think I might try something first and if not happy I can spend the $$$
