Nov 17, 2024 #1 hcallaway Well-Known Member Joined Mar 25, 2022 Messages 598 Reaction score 922 Location Richmond VA Is this the general route?
Nov 17, 2024 #2 dadsbee FABO Gold Member FABO Gold Member Joined Nov 25, 2020 Messages 3,245 Reaction score 7,807 Location Penetang, Ontario No, it goes across the front in the clips.
Nov 17, 2024 #3 mopowers Well-Known Member Joined Feb 15, 2006 Messages 10,649 Reaction score 7,708 Location West Sacramento, CA It goes on the front of the support. It's held in place by the tabs on the front under the top lip.
Nov 17, 2024 #4 doug 371 Well-Known Member Joined May 29, 2004 Messages 3,199 Reaction score 1,772 Location Regina, SK CANADA If you look at the front you can see the wire holders
Nov 17, 2024 #5 dadsbee FABO Gold Member FABO Gold Member Joined Nov 25, 2020 Messages 3,245 Reaction score 7,807 Location Penetang, Ontario
Nov 17, 2024 #6 hcallaway Well-Known Member Joined Mar 25, 2022 Messages 598 Reaction score 922 Location Richmond VA That makes sense!!! LOL I could not find shots that I could see exactly how they routed. Do they feed thru the big odd shaped hole on the driver side?
Nov 17, 2024 #7 dadsbee FABO Gold Member FABO Gold Member Joined Nov 25, 2020 Messages 3,245 Reaction score 7,807 Location Penetang, Ontario Is this a Dart?? I'll get you a clear shot in the AM...
Nov 17, 2024 #8 hcallaway Well-Known Member Joined Mar 25, 2022 Messages 598 Reaction score 922 Location Richmond VA Yes 1968 Dart GT Any shots would be appreciated as it feeds from the back of the support to how they exit.
Nov 17, 2024 #9 dadsbee FABO Gold Member FABO Gold Member Joined Nov 25, 2020 Messages 3,245 Reaction score 7,807 Location Penetang, Ontario Wife told me I had 12 minutes till supper.. lol. here ya go... her '69 Swinger.
Nov 17, 2024 #10 hcallaway Well-Known Member Joined Mar 25, 2022 Messages 598 Reaction score 922 Location Richmond VA Perfect You got it all. Now I hope I can do your pictures justice!!
Nov 17, 2024 #11 Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member Joined Jul 16, 2017 Messages 19,156 Reaction score 16,538 Location Northern Colorado 67 Dart.
Nov 17, 2024 #12 dadsbee FABO Gold Member FABO Gold Member Joined Nov 25, 2020 Messages 3,245 Reaction score 7,807 Location Penetang, Ontario You can see from the lack of paint fade, missing the two ground wires that use to go to that screw..
Nov 17, 2024 #13 Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member Joined Jul 16, 2017 Messages 19,156 Reaction score 16,538 Location Northern Colorado dadsbee said: You can see from the lack of paint fade, missing the two ground wires that use to go to that screw Click to expand... Yep... Pretty cool! I was in the process of replacing the drivers side front fender, so lots of things were disconnected. I also found out that with those 2 grounds disconnected the turn signals did not work.
