[WANTED] Small Block Bell housing
Thank you for your reply I was just looking at that post on EBAy when I was posting this Thread. Can you confirm this is what I am looking for? Or is this the smaller 9.5" one?
I think The Professor covered it nicely. You might have the right z bar already I can't remember for sure.
Thank you. Yes I ordered those parts from Brewers good for the larger bell housing. That is what I am looking to do. Upgrade to the larger later bellhousing. I have most all the parts for that already, Except the bellhosuing.
You may want to specify what bearing retainer diameter your transmission has, since there are several variations on bellhousings.
I only have the smaller ones left in my stash. I dont see a 67 anywhere at the moment.
make sure this is correct...Bell housing 289 2482 = 10.5
Per Brewers on the clutch fork:
  • Reconditioned original clutch fork for the following applications:
  • 1966-up B/E-body with all SB / BB / 426 / Gen 3 Hemi engines.
  • 1967-69 A-body 383 big block applications and used in any 1967-1976 A-body with a B/RB or 426 Hemi engine.
  • We also use this fork in 1962-1966 A-body Small Block applications when using the later model 10.5″ bellhousing.
  • Reference Chrysler part # 2643702
  • 10 7/8″ overall length.
