[Found!] Motor mount brackets for 71 Duster 318
randy4662
New Member
kennesaw
Rating - 0%
0   0   0
So i gave away my old 318 the other day so i could install my rebuilt magnum 360. I stupidly forgot to take the engine mounts off the old 318 block. Now i am stuck, not able to install the 360. I only have truck mounts, and they will not work. way too tall. I am looking for 318 biscuit style brackets. (not spool) that will go on the duster. I have a new QA1 K-frame. Below is a picture of what i need. Yes, i know i will have to weld a tab with these. If you have them with the tab already welded (for the right price) i will take that also.
340/360 have a different D/S mount than the 318.......But, the 318 mount can be shimmed to work.
@randy4662 ill trade you a set of stock 318 brackets and mounts for an a body for a set of truck 360 mounts and brackets. How’s that sound?
