Mono leafs
HR5058
Eldridge, Iowa
What is everyone running for mono leafs. I have Calverts with 1” lift that have maybe 50 runs on them and 2000 miles and one is losing its arch already. I took all possible other variables out and still when i jacked up the rear the right side would come up quicker. On the grounds, bounced up and down multiply times and right side still higher. I took them off and measured and about a 1/4 off. Thoughts please. Thanks
I could be wrong, but I believe the right side is stiffer intentionally, it may just becoming more obvious as they get some use.
I called before and both sides are equal. Same part number. I double checked to make sure there is no writing that said right or left anywhere.
I guess with the Caltracs on, & set correctly, bias isn't necessary..
I know people love their product but through my quick research I could not see where they advertise American steel. Consistency with offshore steel has always been a problem and I for one avoid it whenever possible.
