[Found!] Wanted 1970 to 76 Mopar A Body Driver side bucket seat tracks. Outer, inner or both.
davescuda
Cheshire, CT
Wanted 1970 to 76 A Body Driver side bucket seat tracks. Outer inner or both.
I know that there are some differences in the years, but I don’t care, looking for driver side outers, inner or both
Even need a little work.
Thanks.
Thanks.
Pretty sure I saw a set advertised on here just a day or two ago. That or on FABO. Good luck
Thanks. But I just need driver side ones. Plus those are rusty and will need to come apart and evapo rust and greased and put back together, That’s a lot for what needs to be restore. I can Buy a new driverside set and do no work for that much.
I agree
Layson's sells driver's side new ones for $298 a set. Given the wear and tear on the driver's side it might be worth it.
Thank. I found a new set for 245.00. See is anything used pops up. I don’t mind used and abused. I have some rotted ones I can use for parts. I don’t mind a little rust repair either.
