flathead31coupe
I have the remnants of a fiber or cardboard headliner.I would like to get it replaced.I'm looking to buy ideas and thoughts on the replacement...
Thanks..... I'm hoping someone has had experiences with these headliners.Maybe save me some hasslesI think there are a couple companies that sell some type of PVC headliner and it looks like the original
Thanks for the reply.I kind of wanna do it myself.I just didn't know if to get the cardboard style or the plastic oneAn auto upholsterer can do it. I had my 59 pickup done with a cardboard like headliner like the original
My duster had the cardboard headliner. All that's left is a little piece around the dome light...I want to get a new one installed...trying to figure out witch way to go....do I try it myself, if so witch one....if i have it done do i get the conversion to the bow type or? Thanks
Regarding the ABS headliners: the plastic will last forever, however, the glue eventually fails on the fabric and it will eventually fail and sag. Mine was rarely driven and stored in a garage and now the liner is sagging
Sorry I have another question looking at rock auto it's reads about the 34.5" is between the sunrise or holes. Do I need to ck mine or is that a issue....thanksThe ABS headliner is a better product, and it will last forever. They do take a little bit of fitting, but what doesn’t?
I would recommend getting the uncovered version, it makes it easier to trim to fit and the vinyl covered ones don’t use a very good glue, or at least they didn’t used to. I bought one that was already covered with the foam backed vinyl and it delaminated in the heat. I just resprayed it with adhesive but if you’re gonna do that you can do the whole thing yourself. Plus being uncovered makes it easier to trim to fit. You can leave them uncovered, cover it yourself or have an upholstery shop cover it.
And unlike the fabric ones the ABS or cardboard headliners can be installed with the glass in.
1974 PLYMOUTH DUSTER 5.2L 318cid V8 Headliner | Shop Now at RockAuto
ThanksThey make them for the Duster/Dart Sport and the 2-door hardtop Dart, that ones 40.5”. You want the one for the Duster that’s narrower. They just list the width so you can tell the two apart.
Dave LAYSON told me from his experience he recommends having a CB professional install the headliner. I too have an old one from 72. I trust Dave on his recommendation. He sells the replacement headliner with the insulation attached.Thanks..... I'm hoping someone has had experiences with these headliners.Maybe save me some hassles
Thanks, I purchased the headliner conversion kit from classic industries.I will see how it goes..Dave LAYSON told me from his experience he recommends having a CB professional install the headliner. I too have an old one from 72. I trust Dave on his recommendation. He sells the replacement headliner with the insulation attached.
MOPAR in 73 went to the fabric headliner. The cardboard was used for early 73 models. My 73 Dart Sport has a 72 front end. But later in 73 it had the 73 front end. A MOPAR expert Gary LaPlante in New Hampshire has a 300 acre junkyard. I am friendly with him. He worked for Dodge.Their website says that it replaces the fiber board.That is factory for the seventy three.. not sure if I will need anything extra...
Thanks has anyone done this conversion from the board to the bows? If so any input would be apprecbabe thanksMOPAR in 73 went to the fabric headliner. The cardboard was used for early 73 models. My 73 Dart Sport has a 72 front end. But later in 73 it had the 73 front end. A MOPAR expert Gary LaPlante in New Hampshire has a 300 acre junkyard. I am friendly with him. He worked for Dodge.
Does the windshield need to come out to put in the conversion kit from board to bow type headliner
Ok tyThe fabric type headliners with bows were installed before the glass. They can be installed with the glass in, but it's harder to get them right doing it that way.
How do you install it without removing the windshield...looks like my rubber is pretty flexible...The fabric type headliners with bows were installed before the glass. They can be installed with the glass in, but it's harder to get them right doing it that way.
