Here is my list, in order, to the best performing factory small block heads as cast from the factory (273, 318, 340, 360).
- Magnum heads. Speaking strictly of how they perform from the factory, I think these are my #1.
- X head. Only put this ahead of the 308 because of the 2.02
- 308 head. Gives up some valve size to the X head on intake side, but I like the exhaust port
- J head. Really, this head works as well as a X head in my opinion, but most came with 1.88 intakes, thus it falls to #4
- Smog 360 head, pick the casting. Yep, I put this ahead of the closed chamber 318 heads.
- 318 heads (non magnum) - and pick your poison. I guess the 920 head may lead the way in performance. The 675 casting is not a bad choice either among the 318 heads. Many go bananas over the 302-swirl port closed chamber. I guess stacked up against the other 318 heads, ok. I think from the factory the 675 flows more.
