I am installing a 1988 318 in my 1965 Barracuda and using my original 904 transmission. The rear of the crank is to big so they make a bushing for this application. Today I tried to install it into the crank it went in to loose.. pushed in with my fingers all the way. Doesn't fit snug. Is this normal. I thought it would fit snug and be driven in with block of wood and small hammer..I think the bushing outside was machined to small. 178.mm should be 181.mm what do you guys think.??
