Question about master cylinder.
BornNaked
Hemi of the small blocks
Pittston PA
Hey fellas,
My master cylinder went bad and I needed a replacement. I'm a newby mechanic for these things so I have a question.
When I took off the master cylinder, there's a weird gunk build up on the inside. Pictured
Is this something I can just clean and call good or should I be something more to ensure it will work properly?
Thanks in advance.
Yeah, that's just old brake fluid that seeped out the back because your master cylinder was going bad, held moisture, and caused rust.
The best thing to clean up brake fluid is usually denatured alcohol, which shouldn't melt rubber or take off paint.
The rubber in the booster should be resistant to brake fluid, so your booster should be okay.
Should.
- Eric
Also, being new to this (which is great, we need more people starting off in the field), you did bench-bleed the new master cylinder, right?
- Eric
Right now I have the brakes disassembled for cleaning. But yes, a bench bleed is in the plans.
I have my father helping me. He has a lot more wisdom than I do with Mopars. Got to soak that up!
Pretty sure the brake fluid took care of any paint. Alcohol works for cleaning, water is great too.
