Russ Knight
Hello everyone. A few things here. First, I have a 71 340 and will be swapping it into a 2004 Dakota. I'm considering purchasing Trick Flow heads and was wondering if anyone here is running them and if so what is your opinion of them. I will be running a six pack and was also wondering how well the six pack intake will match the heads and will I need to port it to match the heads?
For information purposes this will be my setup:
71 340 stock block. Will bore it to whatever minimum is required to clean it up, thinking .010. Engine will be line bored and decked. Using the stock forged crank and rods, going to forged flat top pistons. Rotating assembly will be balanced. Howard's 713175-10 (272 int./278 exh. - 0.525 int./0.525 exh.) hydraulic roller with Howards roller lifters. Using either 1.5 or 1.6 Harland Sharp rockers. Truck has 3.92 posi 8 1/4 rear end. If it breaks, I'll go to a Ford 9". Transmission will be a built 727. Lot's of challenges with this swap. Instrumentation / wiring is going to be a big one. Painless does not offer anything, nether does Dakota. Headers will be another. Not sure if 360 headers will work, but that's the direction I'm leaning. Hopefully I won't need to have a custom set built. Anyway, input on the Trick Flow heads will be appreciated.
