[SOLD] MAGNUM FORCE UPPER TUBULAR CONTROL ARMS A-BODY
V71duster
California
Brand new Magnum Force Upper Tubular Control arms for the A-body cars part number MFR161041. Price is $325 plus shipping.
Where's the pad for the bump stops...is there a recessed area
Hopefully this is seen as informational for the seller and sale item and gets to stay (rather than deleted for being a comment on a sale item), but there is no pad for the bump stop on these arms (or many like them) because this design will land the arm entirely inside of the stock bump stop mounting location.
This is a set of magnum force UCA's on my Duster, you can see the bump stop has to be moved because of the design of the arm. The original mounting hole can be seen to the left of the new bump stop location.
img_1641-jpg.1716416974
These arms work very well and add a good amount of positive caster and wheel clearance, but require moving the bump stop and possibly some small trimming on the forward UCA mount, depending on how much "extra" metal was left on the mounting tab from the factory (they weren't all the same).
