Good morning,
I have a few questions for the expert builders at FABO. Two years ago I had a reputable Mopar builder in the area re-build the top end of my 340 Dart Sport. He remedied the “sins” I committed in the 90’s when I attempted a Car Craft recipe build. Part of the build was 3/8” fuel line and a Carter performance fuel pump. After the rebuild, right sizing of the Cam and valve train, I’m left with a 9225S Thermoquad and the Carter pump. After trouble shooting and realizing that I was getting almost 11PSI at the carburetor I set about figuring out how to install a Holley 12-803 Dead-end regulator. This easily dropped the PSI to 5.5 and created vapor lock. Using the old 5/16” return line and a WIX 33040 filter the vapor lock problem went away.
My issue is that I’d like to relocate the pressure regulator closer to the carb and get rid of a lot of the rubber, and at the same time get the improved performance and ease of hot starting.
Would anyone have pictures and ideas as to the ultimate location for the regulator? Also, although I’m not married to the idea of keeping the mechanical pump, I’m also trying to stay away from completely reinventing the wheel over and over!
Thanks
Thanks
