[FOR SALE] 1965 valiant V-100 post for sale
Jp5
Sonora, CA
good things:
• 225 slant 6
• 3 speed auto col shift
• 2 door post
• Big bolt pattern spacers/adapters
• New steelies and tires
• Rolled fenders
• New carpet kit with kill mat covered tub
• New gauge cluster circuit board
• LED gauge lights
• Newly fabricated 2.25” exhaust
• Holly 4 barrel carb
• Offenhauser intake
• Electronic ignition and coil (flamethrower2)
• Scarebird disc brake conversion (w/extra pad set)
• Master cylinder upgraded from original
• Front anti-sway bar
• Lap belts
• Aux Sunpro gauge cluster
• Electronic tachometer
• Interior painted a while back
• Wooden steering wheel (nice!)
• Newly felted trunk
• Milled and ported/polished head with oversized valves
• Coollant overflow catch
• Lowering bracket on rear leaf springs 1"
• Drip rail Thule roof rack with 3 bike carriers (2 mtb, 1 road)
• Led headlights sealed beams
• Radio delete
• (2) 8” subs and amp in custom box
(Cable or Bluetooth connection to your phone)
• (2) 6x9” speakers on rear dash
• smaller starter motor
• (2) mid range speakers on rear Pilars (not wired)
• Custom made Interior side panels (front and rear)
• new red poly front end bushings installed
• new tail light lenses
• newish reverse light lenses (lamps non-op)
• California car with no rust except a coupls small spots on a fender that came from WA.
• starts everytime
not as good things:
• Needs upholstery or new covers
• Needs front end alignment (right front wheel specifically is out of adjustment)
• Fuel gauge and original temperature gauge non-op.
• horn not working
• dash turning signal light not working
• highbeam indicator light not working
• could use paint unless you like the look.
• some mild body work here and there.
This car was listed here about 5 years ago and I got cold feet so I pulled it. Wasn't ready... but now is the time. I didn't clean the car for these pics so don't mind the dust.
$6,500.00
Motivated seller
reasonable offers considered
Justin
Sonora, CA
95370
