I just got back into a Mopar after almost 50 years. Trying to match my high school Duster. I purchased a 72 340 904 Duster 4 months ago. Been trying to tune to get it running right. It has a miss/skip that starts about 1600-1800 rpm. It cranks ok, idles ok with approximately 15# vacuum. Starts stumbling then smooths out and runs OK on up. Here are the specs on the motor from the person I bought it from.
69 340 block, Keith Black pistons .020 over, X heads w/ stainless steel valves, Mopar purple cam (slightly larger than stock), Mopar electronic ignition orange control box, HP exhaust manifolds, Mopar aluminum intake, 750 CFM 1407 Edelbrock carburetor with an electric choke added. This is a list of the things I have tried with basically no change.
I just replaced the plugs with champion RN9YC-no change from the Bosch that it had
Set timing from approximately 0 TDC to 4-5* BTDC- no change
Replaced fuel filter, pulled carb air horn, cleaned out bowls and orifices, set floats to spec-no change
Tried many combinations of set up springs and metering rods-no change
I'm frustrated and looking for things to check from this vast knowledge here. Thanks for any help.
