Blueprint 408 in '63 Dart?
You will have to beat the firewall where the wiper motor bump is to clear the distributor. '63 was never thought about to run a small block. Other than that you will need to make custom motor mounts out of rare 273 mounts. Also the 408 is external balanced so you need to think about flywheel/converter. V8's in the early A's are a pain in the *** for working on them.
schumacher has the motor swap mounts
everything else "fits" but...
you'll need headers-- TTI or doug's (i know TTI fit with power steering, not sure on doug's)
you'll need the factory 90° oil filter adapter-- and specifically you'll need the 64~66 unit that is a true 90 not the later one that's at a lesser degree and will hit the frame. OR a remote mount filter.
you'll need a different radiator. if you upgrade your brakes (if you haven't already) you'll need a combo/metering block that doesn't poke out from the frame too far or it'll sit too close to the exhaust.
a 904 can be built to withstand the abuse it'll take behind a 408, but a 727 would be the better choice. it'll be a tight fit and there will be some body massaging-- namely the pinch weld.
you'll need the V8 center link to clear the oil pan. so be ready to hunt one of those down to pay out the nose for it.
and as Jim said you'll need to beat the firewall back to clear the distributor
Thanks for the other issues I forgot.
Keep forgetting Schumacher is back in business.
I back date the front of the motor to use the original early A V8 radiators (70 and up the lower radiator hose come out the opposite side of the motor).
Drag link, good catch.
90 Degree adapter good, mine had the original 273 adapter on the 360 block so that was not on my radar screen.
I used factory early A V8 exhaust manifolds on the 360 with Edelbrock heads.
Jim
If you just GOTTA have a V8.......Put an HP 383 in it and do something different besides the cookie cutter small block everybody does. It'll bolt right in with all the right parts and the distributor is up front and you don't have to hack the car up just to get a distributor to fit. Plus, you'll have a big block.
....and I said all that as a HUGE fan of Blueprint Engines.
Jim
it's only because it's fresh in my mind (working on #3 narrow body V8 swap this year).
how was the port match between the eddy heads and early manifolds? what'd you use for gaskets to get it all sealed up?
OR he could do the thing that makes the MOST SENSE and leave it a slant 6 car and warm up the old leaning tower of power.
As you do I LOVE my warmed over /6 in the '63 Dart way more than my 360 in the '66 Valiant They run very well with a little work.
Jim
...and you don't "just bash" the firewall in. You must relocate the wiper motor, because on the 63 it's RIGHT WHERE the distributor needs to go. As much of a retard fabricator I am that'd make me stay slant 6 right there. LOL
I have heard both arguments, you can bash it just enough to clear and the wipers still work to you have to install a '64 firewall section and install the '64 wiper motor and bracket welded to upper firewall. I am not sure where the truth lies.
We had one member here who did neither. He shortened his distributor in a lathe. Did the housing and the shaft. It was a work of art.
Vaguely recall that.
Here it is.
When I bought this car it already had an Aussiespeed split exhaust and Intake, as well as a 390cfm 4bbl. Even with that the 170 feels like a dog to me. It will all go up for sale once I start the swap.
Well, it is just a 170 after all. They can be quite peppy however with matching parts and a good tune.
Schumacher's site says that the V8 center link from 64-72 A-Bodies will interchange. Is that the correct span of years? I have see other say 64-66.
In the research I have been doing some say the 727 will not fit with TTI headers? Do you know if that is true?
It is wider, longer, & has a kick-out on the pass. Frt. corner of the pan.......I'd say that would be accurate information. Can You make it fit?.........dunno, but You've got Your work cut out to put headers in an early-A no matter what.
i've worked on a 66 cuda with a 360/727 that had TTI's and i can tell you that they fit though i don't know what mods they may have had to do to get there.
everything is tight on the early cars, even with factory stuff. adding in a bigger, longer transmission and a basket full of snakes only jams more junk in the jelly aisle. so don't go in thinking everything is just gonna slip right in.
