71 Demon Trim identification/name
thechamp
Member
Ironton ohio
Hello all, I need to identify the name of the trim in question and advise on where to purchase. Furring body work my dad has apparently thrown some of my parts out thinking it was something he had worked on in the past projects.
1. What is the stainless called that runs from front of doors to back of the quarter glass. It holds the rubber weather strip for the door seals. Right below the drip rail.
2. The two pieces in that same location but on the inside next to the headliner. I believe they were metal. Probably around 1-2 inches wide. I have no idea if these parts are even available for sale… thanks in advance!
Belt moulding is the one on the door . I think the headliner moulding is just headliner roof trim ? That should get the right parts
BTW … that headliner trim uses special clips that are unique to various years and models . Easy to get the wrong ones .
Possibly…. I don’t own a Demon anymore so I haven’t shopped for them . Someone here will know if they are the same as later year Darts and Dusters .
Dang, I wish we were closer. I have all of that from a parted '71 that I am tripping over. LOL, probably why your dad pitched them.:(
I have those stainless long strips if you need them
Looks like it's stainless spot welded to galvanized steel
If you’re willing to ship them, It would definitely be appreciated. Let me know what you want for The pieces I need
The more I looked at these two upper roof strips the more I see rust on the galvanized section I think you could find a lot nicer ones than the ones I have I'm sorry to have held you up but I don't think these are worth your time
Yes 1 very small spot is..I just don't want you to get junk...I have better...Will get a pair removed soon...I'm sure you can find better
I’m not at that point of the build yet anyway, if you dig a better set out at some point let me know. I will gladly take that crusty set off your hands just to be prepared.
I also need the two inside pieces next to the headlights too.
