To me, If you keep both engines in the 350-400 hp (which seems like it) my guess be a coin toss probably very similar performance, 440 should be capable with a little work to get decently well into the 400 plus hp range and would definitely be the better choice at that point. So to me 400 hp and less 360, over 400 hp 440.I think what the comparison in my mind really is, is this. Will a low mileage RV 440 with 4bbl/mild cam beat a high, high mileage 360 mag with 4bbl/mild cam.
I get the "low compression", but I'm also looking at 80 more cubes and bigger valves. If it's a wash, then I don't want the extra weight and less room under the hood. Nor the WORK !!! LOL
