727 will not kickdown
On my Lokar setup I adjust the cable using the nuts on the bracket.
It most certainly does matter. Like Rusty said, transmissions built before 71 do not have the part throttle kickdown valve in the valve body and do not kickdown.
Don't unless you want to take the parking pawl out and possibly brake the case.
IF the transmission was built prior to 1971, it will not be equipped with the part throttle kickdown valve and it will not down shift.
Thanks, I learned something. Ignorant question: So, do the pre-71 "kickdown" linkages vary the pressure to cause the upshift to be at a higher rpm, but cannot cause a shift down to a lower gear?
What a coincidence, I’ve got the exact same issue with my rebuilt 727. But mine will sometimes when coming to a stop downshift. We think it’s the Governor and tomorrow the tail shaft gets dropped to check it out.
please let me know what you find out.pm me if you like
See post #15.
