Small bolt pattern to standard
Dave Chan
New Member
Richmond, BC
Is there such an adapter to change a small bolt pattern to fit wheels with a standard pattern. I would like a wider rim for a larger tire on my 65 Dart gt
You can pull your axles and have them drilled for 4.5 pattern . I have both on my Swinger.
there's bolt pattern adapters (which i loathe with the fury of 10,000 suns), but that puts you into a predicament of changing the wheel mounting surface, so going "bigger" or "wider" means likely something near custom to fit what you want to fit.
short of making the swap to big bolt pattern, your best best would actually be new or custom rims.
Does anyone know when you swap from Small bolt discs to Big Bolt discs, how much that changes the front track width of the car?
