Purple Shaft Cam Specs??
so, this begs the question: how many "hemi" grinds were there?
asking for a guy i know who bought a project car that came with a 360 and a "hemi grind" cam...
(that may be totall inappropriate for the build and now's the time to swap it out)
only 1 for the big or small block. 284d, 471 and 474 lift and 110 lc.
68 dart 270 taxi package weighed 3420 the 213 cam 471 474 was the best sounding cam i ever had in a 68 318 the good hooker headers 2.02 j heads torker door stop 650 dp unilite 3.23s 727 tf-2 cragars 150 shot
Wow!! What year was that?
My first cam purchase was in 1981.
It was a Crower Monarch 280H for a 440……. It was like $65 at a local speed shop in Sacramento, Ca.
Tognotti’s?
I've only ever seen ONE camshaft called a Hemi cam that was from Mopar. There were several aftermarket grinds. Mopar made one of each for the small block, big block and Hemi. Too bad they left the slant 6 out.
I put a 280/474 cam in my 340 back in the early 90s. I had a local can grinder measure it before I installed it. It came out to 238@.050”. I also had it parkerized since MP was too cheap to do it.
I had a 292/509 purple shaft cam in my 340 back in about 1976.it idled great at about 650rpm with a nice lope and reved cleanly to seven five as this was in a manual with six pak carbys it would pull cleanly from any revs. fast forward to about 2005 and I bult my 410 and installed what I thought was the same cam and I hated it. It didn't smooth out until over two grand and was a pig to drive.
What was different? The early one was on a 114 lobe sep and the new one was on a 105 lobe sep.
thats when I learnt that the tighter lobe sep may make more power but is very rowdy especially in a manual car.
I now have a roller hyd cam with 238/242 @ 50 with a 112 lobe sep and this cam is really well behaved in my 5 speed manual and does low eleven sec passes and gets 23 mpg on a run with a 3.91 diff ratio .
Yes a tighter lobe sep would probably make more power but in a manual drivability is far more important.
I only know of 2 of those cams that Mopar actually offered. Both had the same specs except one had the 114 like your first one and the other was on a 108, not 105. Now, there MIGHT have been an oval track cam with the 105, I don't have the complete list, so I don't know. The 108 508 cam was .508/292 on a 108 and it had 248.5 degrees duration @ .050". It was rowdy. I've run a few. I liked them though, because I always ran pretty loose converters and deep gears like 4.30s.
I've got a Hydraulic flat tappet cam that was in my 340 when I bought it (installed by previous owner) and barely has any miles on it. Just trying to ID it so I can at least write it down on the box if I use it down the road or if I give it to a buddy or something.
In mocking it up in an assembled shortblock, I'm getting lobe lifts of .315" (int) and .313" (exh) which equals .473" and .470". That makes me think it's the 280/474 cam (P4452992), but the .050" durations I'm getting with my degree wheel are 232* intake and 234*. According to the victory library specs, the 280/474 cam should have @.050" duration of 238/238. For what it's worth, I measured a LSA of 110, so that seems to line up at least and all of the measurements I've taken are repeatable.
Has anyone degreed one of these Mopar cams? How close to published @.050" duration specs were the actual durations?
The 280 .474 will measure 234 @ 0.050”.
If you have time take a measurement at 0.006” and 0.008”. You’ll be surprised at those numbers too.
I have known Jim [ James, post #38 ] for more than 50 yrs. In the 70s, his brother went to the US & bought some cams. Some at least were from Racer Brown. He got me a custom grind from Racer for my 440, the 292/292 Direct Connection cam, but ground on 114 LSA. I suspect Jim is referring to a similar cam.
Rusty you are probably correct as I meant to say 106 but as my memory is fading it may have been 108 but all I know is that last one was way more rowdy than the 114 cam I had many years earlier.
Bewy I ran you many times and my car was a surprise to many on how mild it ran but was very quick.
See I always remembered that 114 292 was with a 510 lift but I stand to be corrected!
I threw in the oval track cams because they were routinely ground on a more narrow LSA, plus, as many Mopar cams as were available, it could have been several grinds. I have the fading memory syndrome too. Kitty says it's sometimes selective.
In 1975 those purple cams were 29.95 and 39.95 with lifters and never had much luck with them.I would always go with the Cam Dynamics 15007 and 15010 for a hyd lobe made way more power but they were 69.00 no lifters.
Direct Connection was a great place to buy gear sets 99.00 when Schafer and Dana were 249.00 and Dist. were 39.00 and 49.00 with the chrome box and wiring when Mallory YL's were 49.00 and 59.00 ...
Yeah they had what they called "good guy" pricing. I remember it well.
Car Nut it has 1.6 roller rockers so the theoretical lift is .610 but as we know the theory and actual is very different on a small block mopar.
Yeah, subtract at least .020" from the lift right off the bat because of the horrible pushrod angle, not to mention if the rockers aren't very accurate.
