Steel 8 3/4 gasket, which way????
4spdragtop
Ontario Parts Unknown
Ok, so my 8 3/4 is getting closer, but with my slow progress or slow pace, I forgot which way this steel gasket goes?? There is a small lip on it, but does it face out to the end of the axle, or in?? Also the foam gasket goes on 1st then the steel one correct??
Thanks!!
Anyone help?? does it go in front of the backing plate or behind?? Also the raised lip...in or out??
My understanding is that the metal gasket goes between the housing and the backing plate, and the foam gasket goes between the backing plate and the axle flange.
I would think that the metal gasket goes flat against the housing and the bump faces out to the backing plate.
Anyone else?
Anyone else?
Im getting confused here...no surprise for me though!!
1st put on the steel gasket, lip facing out towards backing plate?
2nd put on backing plate
3rd put on foam gasket
4th Have a nice cold beer!!
Is this right?
Thanks guys.... getting ahead of myself, now I gotta s/blast the backing plates....jeez, 1 step fwd 2 steps back...my own damn fault not checking everything out before hand. Thanks again!
Steve
