rmchrgr
Skate And Destroy
Soooo, I was finalizing the installation of my floor shift steering column into my Dart. The whole thing was in and I was ready to bolt it up to the steering box when I realized it was a couple inches short! I tugged at it a little to see if it was hung up on something inside but nope, no such luck.
Out it came to see if something was out of whack but nothing popped out visually. I disassembled the top collars and t.s. switch but everything looked normal. I don't have a snap ring pliers here at my house otherwise I would've removed the shaft to check it. I have the snap ring pliers at work so I can pop it out tomorrow but I'm a little perplexed as to how it may have happened.
In lieu of that, I figured I would see if anyone else has run into this issue. I do recall seeing the little plastic buttons about halfway up the shaft which are designed to collapse it. I don't however remember dropping the thing directly on the ground or anything like that.
I lined up the collars next to each other and they are the same length. I gotta believe it's collapsed somehow. Maybe when I tightened down the nut on the end? But over 3"? Dosen't add up.
I have a power to manual adapter but I didn't want to use it since the only thing converted here was the floor shift collars - the shaft is from this car which was power steering and will be re attached back to the same box.
Hoping you guys may be able to shed some light here as to what I may be dealing with. Also, is it safe too use the shaft after it's been collapsed?
Thanks for any input!
- Greg
- Greg
