Wtb: Misc. bolts off a parts car. See list
31pickemup
Ohio
Rating - 50%
1   1   0
Hey Gang
My 67 cuda is missing some factory mounting hardware. Here is the list of bolts/hardware I need.
Lower door hinge to door bolts.
Hold hinge to hood mounting bolts.
Radiator support bracket bolts. This is the piece that runs from top center of the main radiator support to the bottom.
front lower valance bolts.
front license plate shield bolts. Not sure what else to call this shield that mounts to the bumper to the bottom of the radiator support. All I know is the license plate mounts to it and is painted black.
Any help is most appreciated.
Adam
Adam,
Contact Daniel Depetro on this site, he probably has most of the bolts that you need.
Yeah 4spd I'm not really sure what length or size they are. The body man has the car and it's getting close to finishing up and he needs some odds and ends. Where do I find Daniel on here demon. Is it just under his name in the members list?
I have a box full of misc bolts & screws I've stripped from A bodies over the years. It's not light though
I've still got the points distributer you said you want from 6 months ago sitting in a box at work, then you fell off the earth and wouldn't return PMs here. If you want parts, will you actually buy them?
