mopardart44067
i have a 67 dart gt project,has been mini tubbed ,springs moved in.frame connectors welded in,it has manual brakes/steering,has motor plate mounts,no gas tank,the underside of car was striped and coated,the inside floor pans were stripped and painted,all glass is good dash is good,has no carpet has some canvas?new door panels,body is straight with some dings here and there,no rust,wiring is clean,has the original small bolt pattern drum brakes up front,7 1/4 rear end (not good for this build)the car comes with a fresh 440 shortblock,and etc,also comes with some new 29.5x11.50x15 m/t drag slicks on some nice used centerline style 15x10 wheels,and front maching wheels are 15x4 with 28x7.50x15 front runners.more info available,serious people only.$2200.
