discharger1332
i am getting everything buttond up on the dart today, i would like to prime the motor before i fire it for the first time. what have you guys used to prime the oil pump?
i would not try to start an engine unless i knew for sure it was going to have oil pressure...and after all it runs on oil not assembly lube...
Ave hardware; 5/16th's allen, and a 3/8" round stock welded together.
