I have been expierncing a huge issue that has about drove me insane and has me very close to giving up on my 360 magnum. I have a 300hp crate 360 magnum in my 91 short bed half ton 4x4 truck, the truck has a non lock up A-518 transmission, I had to buy a lokar throttle valve cable to hook up to the transmission so the transmission would operate correctly.
I have a 650cfm edelbrock avs carburetor on top of a dual plane edelbrock rpm air-gap intake. I purchased a throttle bracket made by AR engineering for the carbureted 360 magnums.
The problem i am having is this throttle valve cable going to my transmission is wrecking havok on the edelbrock carburetors i have tried to run, what happens is the bore that the throttle shaft rides in wears down and i get a fat vaccum leak at the throttle shaft. It happened to a 1405 edelbrock carb that i purchased brand new, so i bought another edelbrock the avs i currently have, and it happened to the avs within 2 months. So i spend 150 bucks sending the avs off to a carburetor shop in new york to have the baseplate bushed with teflon bushings. I got the avs back put it on and my engine idle still varies and the throttle shafts still leak fuel if you pump the gas pedal a few times with the engine off and it just doesnt sound like its running right, I'm starting to wonder if this carburetor shop even bushed the base plate, and i still have real bad throttle shaft play up and down and side to side.
So here is my question, does a carburetor that can handle a throttle valve cable even excsist? I am so tired of fighting these vaccum leaks and i am tired of dropping 300 to 400 dollars down for a new carb every other month. What can i do here? Do i need to just opt for a 5 speed manual and get rid of this A-518 so that i dont have a throttle valve cable?
I am willing to buy one more carburetor brand new and see if the throttle shafts can remain vaccum leak free, The carburetor i have been looking at the most is a quickfuel ss series 680cfm vaccum secondary carb, it has a 4 corner idle, changeable air bleeds, changeable idle feed restrictions and it has teflon coated throttle shafts with teflon shaft bearings. The price tag of this carburetor is 527.00. What would you do? And what do i need to do? Because this is so frustrating i feel like just throwing a for sale sighn in the window and passing this headache on to somone else.
