69 dart suspension
68ddart
tennessee
i was wanting to take a 69 dart and add the magnum force suspension kits front and back.the front and rear kits cost about 5600, but i am still shopping around.i really dont want to spend that much . anybody have any better ideas on improving the stock suspension. i wanted to be able to run it mostly on the street but also run good at the track.
When you say "run good at the track", what do you mean? Drag strip or road racing? Either way, I would talk to Firm Feel before buying anything from Magnum Force.
Do some more research on Magnum Force before you buy. There are a ton of ways to improve your stock suspension although I finally decided to go with a coil over system myself.
Do a good front end rebuild with Moog rubber bushings. Install subframe connectors and you will be surprised how much better the car handles. Find a shop that knows how to align an old Mopar.
thanks for the info. much appreciated!
I TOTALLY agree,there is no way i would spend $5600.00 on rebuilding a suspension
You guys crack me up. The original design is not only "just fine" there's a lot of competitive guys who run it, auto X, vintage road race, etc.
Good basic rebuild plus better shocks, tires, front anti-sway bar, and much stiffer T bars and rear springs.
