[WANTED] 71 demon non a/c rallye cluster bezel
I have a couple must pick up I will not ship it . $200 for just the bezel. No gauges or lense . I have them complete also
You might have better luck if you were willing to accept repairable. All of the 8 various model OEM bezels I have here has some damage somewhere. If not cut for stereo, holes drilled, a corner broken. One is broke where the headlight switch mounts, as if someone didn't know what/how there. Another has a good crack at right side of the climate control area. Somebody failed to remove that one more screw before pulling this bezel away from the inst' housing. DOH! They are repairable but...
Every one has a wavy brim too, some more than others. That is just age/heat typical, damaged elsewhere or not. Bottom line, Its hard to beat a new reproduction.
Good luck
do you know who makes a repop that isn't on back order?or would you sell me a repairable one or 2 to make one?thanks,kent
I had no idea the repop was backordered. I do believe it would be worth the wait.
