73 duster stroker thread
panheadchuck
USA
getting started , removing my r3block 360 mag and sst a41 tranny. And installing my 340 based 422 w2 small block and EA stage 3 2004r with billet converter and transbrake. Got started pulling engine and trans. Lots of stuff for sale ,
Got the Trans, bell , billet converter , flexibility late and pilot going to mate the engine and trans tomorrow. Stage 3 EA 2004r with transbrake. Ill keep ya posted.
Indy W2? 4.0 arm?
Looks cool man. Dyno time?
Yes sir. Been on the dyno. 675 hp - 603 tq on 92 octane. Cnc indy w-2 heads callies 4” crank , callies 2.100 6.125 rods. Diamond pistons 11:1 solid roller.
Ummmmm, do you have anbuildbthread in that engine?!?!?!
I’d like to know a whole lot about it.
I dont have a build thread. Just the car thread. Ask away feel free to pm me ill answer anything u want. I want to keep it under wraps locAlly for a while though . Also running a 250 perimeter plate shot were not messin around this year.
Then u shouldn’t have much of a figment issue with that trans. Kim
No. Its pretty compact considering. USCT sells a crossmember for the A body that is specific to this trans. It has to be welded in. Were waiting for Carl Gerst to send the k member so i can locate it and weld it in. In the meantime im welding up holes and body work in engine compartment where AC , electric this or that. And things i don't need used to be.
