Deceus
Hellwig swaybar 55905 (73+ A body)
Like new Hellwig swaybar. Was barely on 100 miles before I had to take it off for a QA1 setup. 73+, only works with the later spool k-members with the sway bar passing through it. Has adapter mounts for cars without the necessary lower control arms. $80
73+ Spool K-member + 318 engine mounts with poly inserts. Lower control arm locations were wallowed out a bit but were patched. Used it for a while with no problems but upgraded to a QA1 setup so I no longer need it. Want it gone $100obo
