Found this in my trunk, I need some help identifying it as I don't have a part # on the box, the paper or the bar. Unless I'm blind, which my wife might say is the correct answer!
Duuoooooh! Missed that. Good eye.Instruction drawing shows K-frame. A rear bar wont reach the K. LOL
I'll say its replacement for the pre 73 OEM front bar that had triangular forward mounts.
Yes sir. The early sway bar is a long limber timber that goes around the front of the K. 73 and up is a shorter bar routed through the middle of the K. It had shorter end links to, attached at a different point on the lower arm. The forward mounted disc brake calipers didn't collide with it.Ok question #2
If it's for a pre 73, will it work after I install the 73+ bbp swap?
Yes, aftermarket rear sway bar, with front sway bar directions included by mistake.
End link attach clips on pre 73 lower arms are way out toward lower ball joint. 73 and later have the clip closer to middle of lower arms length. I honestly can't define by that picture.
We're all assuming it's for an A body. Really, at this point the only way to tell is to get out there and see if everything lines up. Not bein smart here, but YOU have the bar and YOU have the vehicle it's goin on. It could have been answered "by now".
Most aftermarket add on bars came with a right angle piece to add at lower shock bolt so end user didn't need lower arms with factory clips. Todays aftermarket offers oversized, hollow, etc., that attach same as OEM. In that case you must know what year/type lower arm you have.
Well I was just trying to see if it was for the front or the back first as it doesn't say. I haven't lined anything up on the car yet as I have been busy with dental school, a newborn and yanking drum/Mc/proportioning valve off a junk yard car. I will plan on trying to get it mounted in when I start the rear end and brake swap here in the next couple weeks.
