dibbons
We added a full leaf to the rear suspension of the '65 Formula S (now have seven-photo #1). The rear end is now noticeably higher (photo #3) than the stock attitude (stock photo #2). Currently, the front suspension is up against the rubber stops with the engine/transmission not installed. I am curious how the vehicle will handle with the stock front suspension (factory roll bar) and the beefed up rear suspension once it is all put back together. I hope it will not be bouncing around all over the place. Anyone else try this?
