One Piece Floor Pan install
challengergary
Port Saint Lucie, FL
I am considering buying a one piece floorpan for my 70 FM3 Duster 340 project. Before I pull the trigger, how much of a pain in the *** is it to get that sucker inside the vehicle? How do you do it? Through the windshield area? Or do you have to remove the quarter windows?
My center hump is fine but I like the idea of not having non-factory seams from fitting the two halves instead.
When I was getting to do it someone suggested (too late for me) they put a ratchet strap around the middle and "rolled" it like a taco, slid it in, then "unrolled" it. Sort of like when you install metal roofing on a barn. May not be necessary for you but i was putting a 67 floor into a 65 valiant.
When I did my Duster I went thru the side. My quarter windows were out and Im not sure if it would fit with the window in, especially with the wheel and steering column in the way.
