I have a used 670 street advenger carb. On the bottom there are 2 3/8 ports. One is marked for power brake booster, and it goes on the secondary side. The other goes to PVC valve and its on the primary side.
Can these be reversed? It would make for a shorter hose if I could.
Thanks for your help.
