Lol, about the same for country up to the 90sI liked it better then.
I admit I'm stuck in the 70's and 80's.
Racing is like rock and roll, it got worse after the 80's.
On one broadcast about three years ago, they said they weren't Hemis because the blocks didn't come from Dodge, they were aftermarket. Yeah, ok.We know all the fuel, nitro cars, are Hemi powered.
Why even put an RPM limit on an engine. If they were blowing up at 11,000 RPM the guys would build them so they wouldn't blow up. Losing an engine is a costly problem and also prevents you from winning. So the racers would dig deep to prevent losing an engine. Maybe put a cost limit on the engine instead. I never even watch NHRA anymore after going to Englishtown every year and saw the Mopars in the winners circuit back then. We know all the fuel, nitro cars, are Hemi powered.
That is fucked upThey put the limit on them because the GM platform didn’t make power that high. Simple as that. And when GM doesn’t get what it wants, it snivels. They said they did it because the cost of valve springs was going through the roof, when in fact that is a best a half truth. The biggest cost factor for Pro Stock was running 24 races and all the costs associated with that. Chris McGaha laid it all out. NHRA knew exactly what it was doing to the MoPar platform when it made that rule. It also knew what would happen when they changed from VP to Sunoco fuel. The burn rate was detrimental to the MoPar. All of this has been documented on line. That’s how I learned it.
was it a Dodge Hemi or a Ford Hemi. probably just an aftermarket hemi.On one broadcast about three years ago, they said they weren't Hemis because the blocks didn't come from Dodge, they were aftermarket. Yeah, ok.
Good point Rat Bastid, watching pro stock is like the old IROC series same cars just different colors and ugly at that. I can't stand Magaha ever since he made the comment saying what a PIA Mopar fans were. At least there is one Mopar we can root for , he's getting closer to the Chevies in power and E.T. Even with Mopar sponsoring a few national meets Mopars still can't catch a break in Pro stock right on down to Stock and Super Stock.was it a Dodge Hemi or a Ford Hemi. probably just an aftermarket hemi.
I couldn't help but giggle a little when I read this, considering the reputation most online information has. Not arguing or disputing anything in the post, this just struck me as funny.
I agree that todays pro stock is pretty much like watching nascar six and a half seconds at a time. It would suit me fine if nhra moved more toward the factory shoot out type cars as pro stock. They're fast and recognizable.
I’m sure you read by now that this is coming in an exhibition class for now
A New Pro Stock On The Horizon? NHRA Announces New A/FX Exhibition Class For '22
I'll second that !I liked it better then.
Heck I'm still stuck in the 60's!! and almost the 50s!!!I liked it better then.
My dad and uncle and guys like you are the reason I'm not wearing spandex and peddling down a bike path.Heck I'm still stuck in the 60's!! and almost the 50s!!!
Just like back in the day, they changed the rules to let Cheby's run lighter Per Cubic inch. Mopars were weighed down and the Cleveland Fords were really burdened.They put the limit on them because the GM platform didn’t make power that high. Simple as that. And when GM doesn’t get what it wants, it snivels. They said they did it because the cost of valve springs was going through the roof, when in fact that is a best a half truth. The biggest cost factor for Pro Stock was running 24 races and all the costs associated with that. Chris McGaha laid it all out. NHRA knew exactly what it was doing to the MoPar platform when it made that rule. It also knew what would happen when they changed from VP to Sunoco fuel. The burn rate was detrimental to the MoPar. All of this has been documented on line. That’s how I learned it.
demonjim hit the nail on the head... exactlyI enjoyed Pro Stock more than Funnies or Top Fuel. That is, before GM cried about the Mopar cars beating them too often. A Hemi power band is higher than the Chevy engines, so if you cut the rpm's off before the hemi torque comes into play, you essentially eliminate one manufacturer from the competition. I can't stand to watch NHRA anymore. Same with NASCAR, make the rules to favor the bowties.
